Chevyjoe
did FF 14 bolts come with 4.09, 4.10, or 4.11 gear ratios? i know they came with 3.73 and 4.56 from factory but what was the middle ratio they came with as i thought it was only 4.10s? also, can you run a 4.09 ratio rear with a 4.10 or 4.11 front or vice-versa or is that couple extra teeth make it not possible? finally, im going to be swappin in 3/4 ton running gear and am wondering which gear ratio to go to. the rig is a 86 chevy p/u with a 305 and sm465 and has 35s, but 37s will be next. itll be daily driven, with only a handful of highway trips. i want something thatll be fairly low, but still be able to do 60 if i have to. i was thinkin just 4.10s but then maybe 4.56s? what about 4.88s? any input is greatly aprreciated :awesomework:
