xjpaddler said:Im very interested in this as well, i have a 6.0 lq9 it is in a 03 silverado SS.
Is it worth it to swap heads??
gdf said:I figured the tittle would get attention !!! Pros /cons to putting 5.3 stock heads on a 6.0 I heard they flow better and help build more compression !! Any truth to this
fl-krawler said:If you have a 6.0, I would look for a set of heads off a L92 or LS3.. They should have an 823 casting...Word is that not many aftermarket heads flow as well as they do right out of the box
gdf said:Will springs valves... All the internals work in between the heads or do I have to buy specific valve for the LS3 heads ?
Elliott said:Have you actually built these and ran them, or are you going by what you read?
