I'm in the process of replacing my front leaf springs on the CJ5 due to the passenger side noticably sagging. Is it possible that any of you might know what spring I need to purchase as a direct replacement by utilizing the data below? According to the previous owner, they are lift springs (approx. 2-2.5" of lift when new).
Spec's of above mentioned springs:
-Length (removed from vehicle, measured eye center to eye center): 44"
-Lenth of spring from end to end (removed from vehicle): approx. 46.5"
-Leaf spring width: 2"
-# of leafs: 4
-Large eye dimensions: 2 1/4" OD / 1 5/8" ID
-Small eye dimensions: 1 7/8" OD / 1" ID
-Length from large eye to center pin: 22.5"
-Length from small eye to center pin: 21.5"
I know it's a long shot but I figured I'd throw this out there in case any of you with A LOT of familiarity with leaf springs happen to have come across something like this....
Thank you in advance :awesomework:
Terry
-# of leafs: 4
Terry
