If you screw either adjustment in(clockwise) it will lean the mixture out. You should not need to adjust the power mixture, it is preset at Impco for the correct air/fuel ratio. The idle mixture should be adjusted for the smoothest idle. You want to make sure your timing is correct before tweaking the mixer.
