NotSoPC
So I have a 98 TJ 5spd. I replaced the fuel pump about two months ago. After about a week I am having what I think is fuel issues. It has long cranking starts that seem to be shorter if I pump the gas a little. Can't go over 2900rpm cause it will cut out. Bogs coming off the line in first and sometimes when in second. Runs ruff for a minute or two after starting and shudders when I give it gas right after start like it has a couple dead cylinders them smooths out. Today it bogged while making a right hand turn in third and I had to press the clutch and rev it up a bit then all was fine. Any ideas what to start with? On a budget so I don't want to be replacing the fuel pump again if I don't have to. Any help would be great, thanks.
