Limit straps ????
jossrigs
Southern Middle TN
Going to put limit straps on all 4 corners of my buggy. How much shaft do you want to leave in the coil over so it want top out?
I.E. If you have 14" of shaft showing when coil over is completely extended. Do you want to make the limit straps tight at 13.5" of shaft showing so it can't come close to topping out and damaging the coil over? :dunno:
This may be a dumb question but I have no idea....
Woodlee said:
If your using a good quad wrap limit strap then take the fully expended measurement and take off one and half inches.
Thanks Woodlee. I'm sure the guys setting up the coil overs have some good ones I'll have to pick up!
PM Sent
I'm sure woodlee would have the better answer then me, I've always shot for 1" so it had alittle cushion or room for error and stretch
