85toyo
What kind of brackets are you guys using to swap an ls intake on to a 6.0?
zjtrey said:You'll have to be more specific on which intake you wanna run.. truck intake, or ls1 intake ect...
My understanding (might be limited) is you need to run car accessories with ls1/car intake and truck accessories with truck intake because the pulley's are offset differently and waterpump ports are configured differently for each setup... there are aftermarket setups out there too... there are tons of different options which is probably why you're posting up.....![]()
crawlin85cj said:Truck brackets and turn the intake around backward
NTIDWELL said:Bout to run into the same thing I'm doing ls3 heads and intake on my lq4 they say ill have no problems everything will plug in off of my lq4 harness to everything on ls3 intake ill let you know have it all goes they said everything bracket wise will clear also aslong as I turn intake around that's the way I'm running it now anyways what made u to decide to go with a ls6 intake just wondering
this is true and instead of port and polishing my lq4 heads I decided to go with ls3 headscbfabwerks said:cant run a ls3 intake on a lq4 unless you have l92 heads
ls3 l92 are the same round port flowing 330cfm on intake and 200cfm on exhaust where your ls6/ls1 are cathedral port85toyo said:If you're getting new heads why not get the l92? They say those are the best flowing heads to put on a lq4.
