1TONZR2
Big mudda fugga!
Re: Matt O's S&N Fab Buggy Updates & KOH Prep/Rebuild
looks great!
looks great!
Cole said:Since you have to replace the Front R&P makes sure you replace them with whatever Bryan and them use. They haven't had any problems since they switched to what there running now.
Matt O. said:Thanks for the props, I went through Joe's color sample books with a picture in hand of a paint job I really liked. I found the closest one and hoped that the 1 inch sample would match what I was going for. Turned out better than I expected, even though Joe said the color didn't cover for **** and has something like 13 coats of paint on it including primers, base and clear![]()
Matt O. said:Jimmy is brining new r&p and install kits this weekend, I am sure I will be fine with fresh gears and a stronger ratio. I am with 4.56 to replace the 5.13. I always thought it was too low with the 4.3 atlas, so this will give me some wheel speed in first gear..
CHASMAN9 said:Looks great, now let's go to Buzzards Roost and see how they stand up to some abuse. Need John G. To spot you though.![]()
Matt O. said:Gregg I know the line now also!
Couple of Pics Joe took from the paint booth
New Skins
Cowl & Grill
Old Skins (aka Beaters) We keep the EOR sticker on and then took it off prior to clear. Looks cool IMO
John Galbreath Jr. said:I am ready, I know THE line!!!!!!![]()
Matt O. said:Oh yeah, anybody have the cooler fittings that screw into the bellhousing of a TH400?
Matt O. said:I got it covered, thanks for the research Marty. I found a post by BillaVista on the subject today and talked to him a little about it. You are right about the Straigh Thread but he said you can use an Tapered thread if you are going male to female. That is what he used on his and he is writing a tech article about fittings, so I got WAY more info than I will ever need on the subject. My problem was I was trying to use the brass fitting in the case already that reduces down for hardline. I pulled that fitting and tossed it and went straight into the case with a 1/4" NPT Nipple Fitting that I already bought. I used teflon tape so I should be good to go! I wish I would of found the -8 fitting before cause that allows more flow, but 3/8" should be fine
