Toyotanut
Need a crash course on adjusting my front derailer.
Won't shift down from 3 to 2. Ends up only pushing the chain to inbetween 3 and 2. If I set it to 2 and put it on the gear rubs badly on the low side(leftas you look down from the seat and won't push it over to 1.What is it doing? There should be two philips screws you adjust. If it is too much for you, a bike shop can do it in 5 minutes.
Loosen the cable with the adjuster on the shifter itself.....start with that. The screws limit the inner and outer travel range of the derailer....every thing inbetween is cable tension
How old is the bike? The cable might be stretched... I usually avoid ****ing around with the cable and adjust the screws, but I don't know if that will solve the problem.
