Sweet Run Brian
Thanks for the help howie. The truck kicked azz today.
Sweet Run Brian
Im up for any ideas..... Explain...:corn:
Cut to the chase and put fi on it.(or propane since you think the fi wont work with your pro-stock cam)
FI will work with his cam.
TBI chips told me it wouldnt work. I have all the tbi injection waiting to go on just didnt put it on because of what they said. My cam is mild.
TBI chips is retarded. What's the specs of your cam? The only way it won't work is if the cam is so HUGE that it makes no vacuum in which case you would need a alpha N system like a old pro jection. What commonly goes wrong with milder cams is if the valve overlap is too much then you simply have to run it in open loop. You would no longer have a O2 sensor. Not a big deal just a setting in the chip and maybe some tuning...
I need to figure out how to make the fuel pick up work better in the cell.
if hes having fuel pick up problems, how would FI help?
im in NO way against going FI, i think thats the best choice. but it wont help anything, if the pick-up problem isnt taken care of.
Pm me a number and ill call you when i decide(very soon) to make the change over. Believe me....... I dont want this fuel problem to happen again.....it really screwed me on a climb at the moon rocks.
