Roy_Hobbs
Gettin ready to start another buggy. 1 ton, 4 link, coilovers, double ended ram, tj body back-halved, around 116" on wheel base, custom chassis. Just wondering if anyone has actually ever been able to build a buggy using tj body where they were able to get the tranny and case ( turbo 350 and atlas 4.3 two speed ) flush with the bottom of the rails for a flat belly. I guess you would probably have to do some cuttin in the floor pan and clock the case flat to do this. I was thinkin bout using 2"x4" tubing just in the center under the tub and 1.75 DOM everywhere else. Also, would clocking the case flat cause any driveshaft clearance issues with the tranny.
