tonybolton
Bypass Crawler
Correct....busted! :P :'(
TacomaJD said:I'm generally not a Jeep fan, but that blue ***** is sexy ^^^ drool
ranger11 said:![]()
Sent from my XT1254 using Tapatalk
ranger11 said:![]()
That would be his helps hacienda, surely he's got better tasteROKTOY829 said:http://cloud.tapatalk.com/s/58fa3d0bbbea7/20170421_114655.jpg?
Tony Boltons house?
Sent from my SM-G935V using Tapatalk
. Excuse me for my ignorance here, but what the hell is that?Red97 said:![]()
All done. Finally
zukimaster said:. Excuse me for my ignorance here, but what the hell is that?
TBItoy said:looks like a couple hundred pounds of welding wire
poolman said:X1000 ???????
TBItoy said:So you convert a wedge press to a flat shim setup by filling the wedge pocket with weld?
If I'm understanding correctly
Cool
I had no idea it took that big of machine to make doughnuts.......????. What size (#,?) rolls of wire do you use? It'd be a full time job just changing 50# spools at that rate?Red97 said:![]()
This is what it looked like before I started welding. 8" of the far side shelves were cut out (where the little blocks are welded on) creating a T shape.
This pic is from the front, the "finish weld" pic is from the rear the deeper side.
1300 ton forge press. The area is called the "wedge pocket" normally they install a wedge to make it parallel with the shelves. Slide the wedge up/down to adjust the height.
As the press runs the wedge gets beat into position. Then as you try to slide it, it is now sitting on ridges if it slides at all. The wedge is held in with 3" bolts that keep it from sliding out the back. Lots of times those bolts will work loose or strip out.
This way it will always have 100% contact and can have set shims for different dies.
Trying to bolt a block in place won't work as the force will break the bolts or pull the threads as each layer "settles" in. Same with just welding a block in place. That is why welding solid is the preferred method. Being a cast steel frame, it has to be pre heated to 400* ish and held during the welding. Then stress relived at 1050* and allowed to slow cool.
Once that is all done I get to come back and machine everything back to where it belongs. The frame will move a bit from the weld/stress relief.
https://youtu.be/uVIhmVmN4LI
Here is a vid of one of these presses complete and running. Not this place but same make model for a scale reference.
stano said:I had no idea it took that big of machine to make doughnuts.......????. What size (#,?) rolls of wire do you use? It'd be a full time job just changing 50# spools at that rate?
Red97 said:![]()
biggin said:Is that a Minster press? I've worked on a few of those at our plant in Cleveland Ohio. We have Fuji Cars at our plant here in Tennessee.
Red97 said:Ajax.
I've cut the bed on a fuji before lol
