blacksheep10 said:lower the uppers if its easy. I suggest raising the uppers and lowers on the axle. get that roll center up and gain side hill stability while at it. I would start with going all the way to full bump and raising the upper on the axle til you're out of room. get them links flatter. they should be inverted at full stuff assuming a fair amount of uptravel.
Ok, I looked at the rig for a second this morning, and it looks like I can only get 1-2" from lowering the uppers at the chassis. :-\ I will probably look into raising the uppers at the axle as much as possible before they hit the floor. I might get another 1-2" there as well.
The lowers are currently right at, or slightly above, axle center-line.
