Hellbilly
Any one running propane in there suzuki?
What do you think of it how was the install ect ect
Hellbilly said:Are you going with a gotpropane set up or some thing else?
A Friend mentioned building my own using a fork lift propane set up!
I saw the oil out of a mid 70s ford the motor had about 100,000 miles on it that was running propane and the oil on the dip stick looked like it was dipped it a new qt. of oil.
Hellbilly said:I saw the oil out of a mid 70s ford the motor had about 100,000 miles on it that was running propane and the oil on the dip stick looked like it was dipped it a new qt. of oil.
Hellbilly said:Any one running propane in there suzuki?
Thats cause pane doesnt leave deposits. You still need to change the oil as its propertys wear out.
nuzzy did you buy propane bottles from gotpropane or are you going to buy locally? Are you going with steel or aluminum bottles?
got propane is way over priced. propaneguy is way more reasonable and will work with modded engines
my
$.02
Ok thanks? But would you saying my 80 hp motor is modded?
I will look in to the propaneguy to compare prices!
nuzzy I saw the weight of the aluminum bottles on your build thread! Is that empty?
propane weighs about 4.5lbs per gallon if I remember right about half what gas weighs
What do those two steel cylinders weigh, along with mounts, compared to a fuel cell?
I'll probably be going with aluminum tanks from The Tool Store 516-747-0651.
my
$.02
