Knok2222
On my sas setup im using all pro 5" front leafs and ran into an issue. The spot I found to mount the shackles for the rear pack is like most yotas in between the mount for the body on the frame. While punching the hole through the frame with the torch tonight I found a small square hole up and right of where my hole was. Maybe 1/8" away. had some sort of plastic plug in it. To me this looks like a VERY week spot on the frame. Even with the huge plug welded in place. Are you guys plating this area? or re-enforcing it at all? I want to put a 1/4" plate there to make the frame stronger in that area. waste of my time? what ya think?
