TheMasterbater
The advantages to rivots are obviously an option of easy removal to access anything. But do you get bad vibration in the sheetmetal? I really dont want to spent 2000 hours tack welding it all.
used screw/nuts...it rattles sometimes but I can tighten it up and off I go.:redneck:
Lay a bead of silicon down where its going to contact other metal... that should get rid of the vibs and still allow you to use the rivots
Rivots it is Back to the garage i go to drill 9 million holes :cheer:
Self-tapping sheetmetal screws are fast and seem to hold well, I would weld the floor and silicone is a great glue
The rivots are actually working out quite well. :awesomework:
What material rivots did you go with? I like aluminum but they do tend to pop loose now and then, easy fix though. Stainless is much stronger but a bitch to get out later if you need to. Steel is plenty strong enough but will rust.....
rivets belong on airplanes
