Six Shooters vs 5th stud
Flat-Bed_3rd_Gen
Enumclaw
So I was doing pricing for my knuckle upgrades and after pricing out arp studs and 5th stud upgrade it's only $90 cheaper than tg six shooters. I was wondering if anyone has exprience with both. Would i be better off just saving the extra $90 and going tg or just going arp and bobby's 5th stud kit and using the money elsewhere?
Any opions are much appreiciated
Thanks James
Haha whoops forgot the specs.
I'm running 37s 529s open front and it's more of a trail rig but I play on some rocks every now and then
James
edit: i was pricing out all 16 steering studs, Do I just need the top 8 or all?
i broke a couple studs on my knuckels.. i didn't upgrade to the 6 shooter i still have the 4, i had to helocoil one, the other broken stud was able to be removed.
i replaced TOP 8 studs with the ARP it cost $72 but i havn't had any problems yet.
Bobby Long makes the "L" tab, i guess that is what you are calling the 5th stud... i have seen it on rigs after i did my swap, i have not heard any complaints.
i am running 38.5x15x15 boggers, 5.29s, locked front and rear, drive flange hubs (no locking hubs)
Its my beliefe and experiance the 5th stud will hold up nicely to hard abuse.
One nice aspect of that setup is if you "do" ever have a problem be it a failure of the studs or something un-related to it you can easily find replacement parts localy.
if for some reason you do break the ARP stud it is a no question ask lifetime warrenty - Trail Gear
however if one of those studs do break its going to be a biotch to remove from the knuckel
I haven't done any mods to mine, other than new studs from Toyota when I put it together...but my rig is only 3K lbs too, running 35's!:redneck:
Have seen a couple 6shooters, and helped install a set on one of our member's rigs...seems to be holding up for him just fine! Seen several 5th studs run with no issue, and they've been thru some good abuse!!!
I'd say with your current setup, run the 5th stud and spend the savings somewhere else :awesomework:, or mail it to me!!:fawkdancesmiley:
i made my own 5th stud and am running stock studs for the rest. i make sure and check the torque every other trip out and have had good results. and it only cost me time as i had everything in the garage to do it.
my bud jeremy has the 6 shooters and the pins broke and one bent pretty quick! so he did the trunion elim. kit and it has been good since.
as far as local parts go, you can put a 4 hole arm on the 6 shooter knuckle and you can put a 6 shooter arm on a stock knucle also.
From what ive seen most of the time when you come aross someone on the trail that has broke their steering arm studs. If you look one or to of the studs are rusty on the top. Witch leads me to beleave that they were broke for a while.... If you keep them tight N check them often. You will find any problems before your stranded on the trail.
It seems that most guys that break studs, don't check them very often. I check mine all the time and have yet to break one. That being said, I just got a 5th stud kit from Bobby!:D Nothing like insurance!:awesomework:
I agree with the checking the torque often, But its a moot point if the studs arnt bottomed out in the knuckle. I wheeled my old toyota with 4 stud hi steer arms(stock toy studs) and 38.5 sx's for a year with no issues.
I have six shooters, with 20 ARP studs total.
I didn't HAVE knuckles when I did my build, so I said the hell with it and bought the TG kit.
I actually was refering to using stock knuckles and doing the 5th stud conversion more than ARP studs. Breaking a modified stock component is far easier to source a replacememnt locally than trying to deal with a company thats not local.
I have been running my stock 4 stud knuckles and recently added a 5th stud. 5.29s locked & 35"s. No issues yet after 4 years (1 year with 5th stud). I do check the touque every so often.
I ran 4x4 labs high steer (longer than normal hy-steer arms) with ARP studs. Full hydro steering on 37's with no problem but did frequent checks on the torque. Lots of rock crawling.
4x4 labs has weld on six shooter plate, I have it on my 85 I'm running 40'' Iroks and punish my truck in the rocks, I Replaced all my studs with stock Toyota studs I've had this set up for a year and half so broken studs and they don't come loose. I think the weld on plates were like $50 I'm very Impressed :D
