T Toyotanut Well-Known Member Joined Mar 27, 2006 Messages 2,840 Location Crustys Brewery Sep 10, 2009 #1 what are the pro's and con's to both? Any one better than another? Lets hear it
N no excuses Well-Known Member Joined Mar 27, 2006 Messages 1,093 Location Rainier OR Sep 10, 2009 #2 Pro's to studs, have better clamping and less likey to damage threads in block, Cons harder to remove the head.
Qman The Camshaft Guy Joined Dec 28, 2006 Messages 194 Location Bonney Lake, Wa Sep 10, 2009 #3 no excuses said: Pro's to studs, have better clamping and less likey to damage threads in block, Cons harder to remove the head. Click to expand... That is it in a nutshell. Studs will handle more compression. Best if using a turbo set up or any high performance build.
P Pook Well-Known Member Joined Oct 30, 2006 Messages 1,748 Location LAngley BC Cana Sep 10, 2009 #4 Studs, you can torque them better. Also helps line up the gasket.
