So my rig is finally starting to come together, slowly. I have the DD Machine doubler installed with a D300 behind it. I have been doing some reading about trying to build a cross member to help support the weight of the D300.
Right now the motor mounts are solid (no poly bushings) and the trans is mounted on some poly pucks to the crossmember.
Just looking for some ideas for the rear cross-member. I have read about some folks that added a x-member in addition to the trans mount and others that removed trans mount and only used one on the t-case.
Any suggestions?
Any suggestions?
