HillbillyPlumber
anybody on here that can dismount and then remount on new wheels 5 36' swampers? How much would you want?
what type of time frame you thinking.....I could do it
TSL bias swampers? or Iroks? or...? That makes a difference too...:redneck:
why does that make a difference a tire is a tire you take it off and put it on the same:haha:
come over then:corn: , I have a 38x12.5 TSL bias ply for ya to dismount:fawkdancesmiley: . Tires are tires right?:awesomework: I have mounted (4) 39s in under an hour EASY while talking to a friend and then struggled for over an hour on "ONE" 33" SSR because it wouldn't seat on the bead, plus mount/dismount was a PITA.... But hey, tires are tires rgiht?:awesomework:
You change oil, not tires:fawkdancesmiley: :kiss: ...or used to.....?:eeek:
Bring it on over..... I'll do it. Have done it before:;
You're not gonna "charge" me like last time?:eeek: :redneck:
You have the lube?
Most of the difference in how hard tires are to mount and dismount is because of the drop center of the wheel. Tires themselves play a small part but it is usually the wheels that make the difference. As far as lube. All that is is liquid soap. I would help you do it if you wanted to come to Yakima.
Majority of sidewalls are only a 3 ply. The bead will play a part depending on tire, but the drop center of the rim will also play a big part.:eeek: Are you serious? It has more to do with the sidewall and bead of the tire than the rim.
