Tool descriptions
Beyer
DC1
Okie Homa
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted race car body part which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench at the speed of light. Also removes fingerprints and hard- earned calluses from fingers in about the time it takes you to say, 'Oh s#!t'
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes until you die of old age.
SKILL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER: An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt heads.
If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race.
TABLE SAW: A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
BAND SAW: A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of everything you forgot to disconnect.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50-cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
UTILITY KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as leather seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
DAMMIT TOOL: Any handy tool that you grab and throw across the garage while yelling 'DAMMIT' at the top of your lungs. It is also, most often, the next tool that you will need
Here is the definition of a TOOL
When Jody and Jack Graef were a team, they helped me out a TON, and I helped them out many times as well. Jody taught me MANY secrets of strategy and racing early in my rock crawling days. This was several years ago, but Jody has always been a cool cat to me. However, his video persona is a little different than most. I would classify Jody the same as I would 99.9% of people in this world, especially overconsuming, capitalistic America: take what he says at face value, no more. Everyone says stupid stuff, some more often than others, and some get caught more often. :shrug:
BTW, Jody "fawkin" Everding was coined at Globe, AZ. One of the stupid things that has vomited out of my mouth. Guess it stuck. I did a little "skit" of Jody at the bar to Jeff Mello; of course Jody was standing right there. Jack and Bob Roggy spewed Lone Star everywhere.
Any funny Jody stories from KOH?
Just Jody being Jody, he rolled in hot rodding to camp after all the "keep the speed's down" and all that... which ignited a big drama llama fest by the main tent. He was rude as **** and mouthy but basically what you'd expect from him I guess. Dave told us " **** man, Ive been dealing with Jody for 5 years " laughing1
I used to think he was cool as **** and always wanted to meet him but seriously, he's just a SoCal dickhead from what I got to see.
I wish I had some pics of my frat-tastic ass in undergrad at Texas Tech, my pic would probably be right below Jody's. laughing1
