MIG'DHORSE
how necessary is this tool? i understand it's part of "building it right" ...but do i need this? I'm building up a front end right now and i've pondered this possible problem. thanks in advance!:awesomework:
If you keep track of where the stock shims came from and put them back in the right spot you dont need it
so if a guy goes to crossover with new arms and the like, he HASto get the tool and set it up this way? What exactly will happen if he doesn't?
IF, and only if, you're also reusing the original arms... Put new arms on there and the trunion preload goes out the window.
I heard a rumor that the lower shims were mostly for alignment, the uppers for preload. I ended up using the same lower shims, and just changed the top ones to get the preload right, and it ended up working out for me also.
~T.J.
nah i think he has a higher chance of worn tunion bearings early on.
