Toyota 3.0 question
Brian H
The engine blew a head gasket and when it was running I pulled the oil fill cap off to look for water in the oil and the engine ran like **** and died. Started it up again and pulled the cap off again and it ran like **** again until i put the oil cap back on...WTF causes that?
It's a blow-by problem. Massive amounts of positive crank case pressure, that creates a weird vacuum leak type symptom (when oil cap is removed while running). That engine is garbage. scrap it and go with a 22re or a 4.3 vortec. You'll be very happy in the long run. But I am sure you have heard all this before:D
3.0 are boat ancors (go sbc) and if the head gasket is blown why does it matter? the isue is just a loss of back presure in the block wich is probly why more then it should be because of the blown headgasket
math 1 part blown headgasket 2 parts extra presure in areas of the engine that dont get that kinda of presure it would be equal to blown rings and pulling the oil cap off
**** small block chevies.
that's all I have to say about that.
I'd rather have a 3.0.
And 3.0's blow combustion gasses into the cooling system when the head gasket goes.
Not even close to the same thing as bad rings and excessive crank case pressures.
Unless the coolant takes out the rings/cylinder walls, then it'll have excessive crank case pressure.
That usually takes a while though.
No, it's not blow-by.
The crankcase is supposed to nearly nuetral pressure at idle, it has a fresh air (atmosphere) inlet and and PCV valve.
OPening a big hole in the crankcase (oil filler) creates a new/different inlet than the one in the intake tube, screws up the flow that the rest of the thing was designed around.
3.4 maybe. No pushrods. :awesomework:
(yes I hate chevy, sorry)
This is correct.
It's designed that way. The 22R/22RE and 3.0 and probably quite a few other engines all do this. They also splatter oil everywhere when you take the cap off.
A lot of people misdiagnose this as "Blow-by" which it is NOT.
As far as your headgaskets go. The 4Runner is worth a LOT less than the truck for whatever reason. I think you would have a hard time selling it at 1200.00 but You can get the gaskets done for about 900.00 out the door assuming everything ran fine before they blew. At that point the rig is worth more than 2000.00 probably more like 3500.00
This is correct.
The rig is worth what some dumbass(?) is willing to pay. Anything 3.0 aint worth crap.
Very true, They sell for 1,000 to 1,200 all the time for fairly clean ones.
People try and get 1,500 + all the time but I usually see them on Cl for months.
I agree kinda. the 3.0 has it's problems for sure. But what engine doesn't? The 22R also has problems. It's just way way easier to pull and much cheeper to fix.
That pic you have there shows some serious neglect. That doesn't happen like " I was sitting at the stop light in my well taken care of 3.0 and boom"
No that story usually is preceded by "I pulled RIGHT over" :rolleyes:
IF you had the money I'd say find someone who can slap a set of HG's in and then sell it running cuz it's worth more to you that way.
I guess in your vast knowledge of mecanics you know there is only cooling pasages in a head gasket also you must know there is no oil return pasages either next your going to tell the hole world your an enginer for toyota ....
And you still don't even understand what was explained above. Was it because he spelled things correctly and used punctuation?
or are you just pissy cause i only said sbc and dident want to waste every bodys time listing every possible good engine swap...Why dont people just give there opinion and not run around telling people there wrong besides I dident post this for you to give me your opinion your suposed to be telling him what you think it is, not telling me what you think it is not
So far, you're the only one with bunched-up panties. Your credibility is diminished when you advocate "people just give there opinion and not run around telling people there wrong" but you keep responding to other peoples' posts, implying that you're right and they're wrong.
I forgot bulliton boards everybody knows everything....
You can't have it both ways son.
And to the illiterate guy withthestupidlongscreenname: Actually, I DO work for Toyota, have for over 12 years.:flipoff:
then you can't deny that the toyota 3.0 is not a very good engine.:stirpot:
If you don't ming getting shitty fuel economy along with not enough power and possibly working on it alot, it's GREAT.
I bet the one I'm building right now goes well over 200k with no major issues :corn:
