All the info you need...
Springs!
44044 SPRINGS
44044s are Rancho Jeep Wagoneer Lift Springs.
Length: 47" (Length is eye to eye)
Center Pin split (front/rear) 22.5"/24.5"
Bushing: 2 3/4" & 3"
Lift: 5.25 - 5.5" (Lift is approximate and uses 1.5" longer than stock shackles giving 3/4" of lift)
Cost: $250 (Cost is for both sides incl. shipping/give or take)
44044's do not (by themselves) move your axle forward. They are the same length on the front half as stock toys (22.5"). While they do move the axle forward because of the lift they provide (arch in spring), when they compress to the point that they are flat, it's the same. Estimated 1/2" of actual axle relocation forward.
http://bbs.off-road.com/wwwthreads_u...ith%20dims.jpg
ALL PRO OFFROAD SPRING LENGTHS by Chris Gieger
Part Number, Overall Spring Length, Center Pin to Front*
TOYFRONT5, 47 5/8", 22 1/2"
TOYFRONT4, 46.1/2", 22 1/8"
TOYFRONT5STK, 46 3/4", 23 1/8"
TOYFRONT4STK, 45 5/8", 22 1/2"
TOYFRONT3, 46", 21 1/2"
CHEVY SPRINGS FAQ Probably most common rear lift springs!
Everything you ever wanted to know about Chevy Springs!
http://www.pirate4x4.com/forum/showt...threadid=20665
If you actually have a question that is not answered there, that would be a great place to ask it so the answer is there for everyone else.
REARS SPRINGS UP FRONT Probably most common front lift springs!
Rears Up Front (RUF) FAQ: http://www.pirate4x4.com/forum/showthread.php?t=265669
Stock toy rears move the axle forward 2" because they are only 20.5" on the front half where as a stock toyota front spring is 22.5". But you have to add a few leaves to the pack to make them stiff enough to hold up the front of the truck.
WAGONEER / WAGGY SPRINGS
These are stock Jeep Wagoneer Springs
Bushing: 3"
Lift: 3.5 - 3.75"
Cost: $200 New, $60-$100 Used
From JcWhitney.com:
1976 - 1992 Jeep Wagoneer, Front Leaf Spring
7 Heavy-duty Leaves #07ZX2048P $99.95 Ea
5 Leaves #07ZX2047B $84.95 Ea
The 7 leaf is supposed to be the ones you are looking for.
Pinion angle can be an issue if you just bolt waggs to the stock location. If you have dropped hanger or dual cases the problem is lessened.
Misc. Spring Information
http://www.4x4spot.com/spring_swap_info.htm
http://www.4x4spot.com/misc__spring_information.htm
