Yup, I run it both my rigs, and my friends rig. we did shim his piston for more pressure, and has worked fine so far, we were worried the pump wont last long, so we will see.but on both my rigs I just drilled out the brass bushing to alow more flow.
cool thank thats what i needed to know. I was worried it didn't have enoughf pressure and i would not responed well. I didn't want to buy a high pressure because i mite go vortec.
I used a toy pump drilled out and with 2 shims added and it lasted for a couple years. Get a reservoir and a cooler. How quickly a pump can move volume is just as important as pump pressure. That's what the aftermarket pumps do well at.
ya i guess i should have mentioned that, we have a cooler , and a semi truck steering resivour for a resivour.it holds like 2 quarts of fluid, and the cooler is just a tranny cooler from vatozone.
I dont rember the size off hand but when you pull out the fitting and turn over you can see how thick the brass part is, drill as big as you can without drilling the brass out completely.
