CrustyJeep
Is there some sort of rule of thumb for heat setting when welding two different thickness material?
For example, say you're fillet welding some 1/8" edge on to a chunk of 1/4"... Do you just set the welder is if it was all 1/4" and modify your weld pattern to concentrate more heat on the thicker material, or is there some rule of thumb to arrive at a lower heat setting?
P.S. CRASH we need a special metal working forum
