what size coilover springs ? toyota pu
bigs10blazer
,,, doing a 4 link in the rear of 88 toyota st cab v6 5spd long bed,, cut the bed off , running 35 swampers and toy axles looking at doing a tube bed with tank and small tool box, looking at the fox14 coilover 2.0 shocks, what springs should i put on the shocks, anyone got a good starting point for me ? doing leafs up front , we want good articulation in the rear , but stable, thanks
I have a jeep yj with tube backhalf....look at build..poorboy rockhopper..... I order 16" dual rate coilovers with 18" 200lb lowers and 14" 150lb springs and it was too stiff and gave me approx 8/9" uptravel. I am swapping to 18" 150lb lowers and 14" 100lb uppers. Shooting for 4/5" uptravel
I would guess a 16" 150lb and a 14" 100lb would be very close
so would any one have a these they are not using ? we are going to try the ) Fox Shock 2.0 X 14.0 Coil-over Emulsion Shock 980-02-011
Weigh it and call EOR. They will sell you the coilovers valved cheap and swap springs with you a few times to get them right. Jimmy knows his ****.
Seems stiff as **** to me. I dont have coilovers in the rear but do in the front. But i use coilover springs for my rear suspension. They are se-up as normal coil springs captured on both ends. And i run 14" 175lb
Up front on my coilovers i run 150 bottom 100 upper. Of course your heavier in the front.
this is what we started with 3.0 5spd ifs,, going to 35s solid axle and 4 link rear and fox coil overs
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
still got a long way to go
i should mention this is my 15 year old son, hes been wheelin/driving toyotas since he was 11.so now its time to go bigger and have more fun
[/URL]
his first toyota
