RE-ntal
NICE TO SEE THE RENTAL COMIN ALONG , YOU SHOULD RECONGNIZE PART OF MY RIG ANYWAY YOU DID THE TUBE GREAT JOB ! its almost ready for a test run to maybe by the hangover run hopefully before is the rental wheelin yet?
Here's a little progress I made a few weeks ago. This project has been on hold due to trying to buy a piece of property with a much larger shop but...
After the front suspension was done it was obvious that the driveshaft was going to hit the lower link, the front shaft is a 2 piece that runs thru a custom carier bering thingy I made so I have options of where it can go on the upper end. The solution was to rebuild this frontend for the 3rd time in a year and put in a high-pinion along with some other goodies.
Jason decided to go with hub flanges so while he tore the rest of the axle apart I drilled the hub for the 6 dowel pins
Originaly I was going to put the detroit out of the original 3rd in the hp but realized it wasnt going to work, as the old 3rd was a 4cyl and hp's use v6 internals. I wanted it back togeather so I robbed the ARB out of the back of my wife's 4runner project and stuffed it in the hp 3rd along with a new set of 5.29's.
We also installed a set of 6 shooter knuckles and high-steer arms to help cope with the hydro steering.
All back togeather we now have no driveline interfernce isues :awesomework:
I also got a nice little puzzle
Custom designed fuel tank :D utilizes the stock pump and fits great.
Looks great,Love the aluminium tank:awesomework: Get that thing done already...we missed you at naches this year.:D
*project update*
I looked at it for about 15 minutes yesterday, that was all :D :fawkdancesmiley:
Anybody have a dual ended steering ram they dont need?
Made ya look!
Nothing's changed. I dont even like building things anymore :rolleyes:
I'l finish it 12 hours before memorial day weekend this spring as per usual:D
I just finished reading this whole thread and damm. I have seen a ton of toy to buggy builds and the design on this one is killer. I would have loved to see you bend up that one rear tube:awesomework:
I cut the runner up and it will be done before the rental:fawkdancesmiley: :fawkdancesmiley: :haha: :haha: :stirpot:
way to go...it happens though with Mr. Daniels at your side. :redneck: :haha:
Does your toy have the 5.0l in it? We met someone last year or the year before in your group that has a 5.0l in their rig, they were have radiator issues up in the snow.:mad:
