1 Ton YJ Build
With a notch like that in the frame you should tube the whole front to make it a ridgid unit. Or you could just web wheel it like it is and be like Paulie.:haha:
are you putting high steer arms on it?
Id put high steer arms on it and toss the tierod on top of the arms, you can run your ram from the top of the center section to the tierod in between the springs. you might have clearance issues with the tierod and frame at full up travel. might have to notch again.
Dude quit yappin on this **** and go work in the garage! I was told you'd have this thing done by new years:fawkdancesmiley:
:kissmybutt:
Well that just aint gonna happen. dont you have an engine swap to do, and maybe a new rad to put in? :flipoff:
I will if I run the steering up above.
No ****...kids these days just have no motivation :haha: :fawkdancesmiley:
are you kidding me? go back to making fun of sam :flipoff:
This is what I want to do. I narrowed the long side 4.5" so I'm a little concerned with fitting the ram in there. I know I dont want to weld to the cast center section, maybe off the diff cover.
You never want a hydro ram mounted to the tie rod anywhere but right near the end's. It will then double as a hydraulic tie rod bender.
