jmc said:What is the advantage of a 70 or 80 over a 14b ?
jmc said:Will the gear rotation be correct in a14 bolt if used as a front end ?
so where are you buying dana 80 axles for 100 if you can ill take 20 right nowtonybolton said:They're usually half the cost of a 14b bolt. So, 200$ vs. 100$![]()
traveler said:so where are you buying dana 80 axles for 100 if you can ill take 20 right now
