joemo
Member
I have a 22r got tons of blow-by so i decided to pull the oil pan and head off oh also had low compresion in the #3 cylinder. So i found the #3 piston had the rings lined up and there is a chunk missing on the side looks like the ring was not put on right and started chipping away or a screw got in there. So here is my problem now i dont have tons of time but i have a ring pattern in the #3  cylinder you cant really fell it in the #4 but the #3 is there. So i need to no if i sould pull the rest of the engine out or just try to hone it. Need some help also if i hone it should i use the same size pistons it is at a .5 right now
