It should be on the passenger side a silver finned box unless its a newer harness I don't think those have them.
do you have the circuit open relay on the passenger hooked up yet? yes if the whole system ran in the other rig then you either hooked up something wrong or forgot to hook something up... as far as i know all the circuit open relay does is control the fuel pumpKinda what I am figuring.... im fairly certain it does not control the pulsing of the injectors What does then???:booo:
FYI there is no silver/aluminum rististor box in the newer rigs...
how much of the harness did you chop up? And did you swap in the fuel tank/pump/sender/complete intake and wiring,computer sensors ect ect...
I didn't chop up ANY of the engine bay harness. The only thing I have "chopped" is the circuit opening relay.:;
I used the fuel tank/pump/sender/complete intake and wiring,computer sensors ect ect...
i am not certain what controls the firing of the injectors... maybe look on pirate or yotatech for some info on this?
interesting... if that is the only thing missing like you say then that must be the issue:eeek:
Is the igniter coil assembly bolted down?
now that i think about it. i somewhat remember there being another circuit open relay around the steering column side of the dash... how long ago was this system up in running in another vehicle?
Do you have a check engine light wired?
You could hook up your test light and grond E1 i think it is and it could give you an idea of whats going on. Im thinkin your missing a B+ wire on your ecu I just efi'd my truck last week and went through all this.
My ignition splice might not be correct. All I did there was hook my original coil wires to the new coil, and hook up my factory starter wire up to the new starter, so it will work off of my key.this isnt you..is it?
if not, there might be something useful there...
http://www.toyotanation.com/forum/showthread.php?t=327429
No, that's not me, but I have read that a couple times already:redneck:
and are you sure you're ignition splice is correct? doesnt it the signal from the igniton/dizzy?
I remember there being 3 or 4 wires that had to be hooked up to power do you have a schematic for that year engine I cant find a fsm for that year
i thought you might have already seen it.My ignition splice might not be correct. All I did there was hook my original coil wires to the new coil, and hook up my factory starter wire up to the new starter, so it will work off of my key.
do you have the ECU mounted? does IT have to be mounted/grounded?
im saving this thread...
my nephew is doing this very same thing right now. not sure how far along he is tho....not this far i dont think...
I have a copy of an '88 specific FSM, but mine is an '89. I dont know if there is a difference or not....
88 and 89 are two different birds...it may be that you've hookeded the original coils wires instead of the coil wires in the new harness...:awesomework:
88 and 89 are different. the ecm does not have to be grounded.
i would recheck your splices. something is hooked up incorrectly, if this thing was running fine 10 days ago
how much splicing did you do and to what did you splice? gauges/ignition ect... E1 is ground.
if you truck fires up when you spray into the intake then i would think that your coil and ignitor are hooked up properly.
That's what I was thinkin.:awesomework:
I am using the 22re harness ONLY for running the engine. I am using no other plugs, lights blinkers wipers gauges....none. The only real splicing I did was the ignition and the fuel pump. Everything else should be ran by the computer. Right??
