35 spline axel seals?
Hip
Paradice
ok i have a morphed front 60. it started life as a 99 dodge 2500 unit bearing.
i retubed the long side and cut the short side to make it 80 size dodge or chevy....
the long side tube was machined for a seal area when installed. so the new 35 spline seals fit right in.
the short side however was never removed and is machined for a stock 31 spline seal. much smaller OD in the tube.
is there another seal i can use that will fit the bore and strech over the 35 spline seal area 1.565"?
Now that you mention it hippy--I have never noticed a difference in a 60 axle seal. I have only used one seal.
ok i wrote the dimentions on the box and left it at home but this is what i need
OD 2.375"
ID 1.562"
thanks tom ill look. now that you mention it it does look like a 44 seal OD....hum.:redneck:
