91 XJ, 5 speed, 4.0 HO, etc etc. Pretty standard.
It doesn't shut off when I turn the ignition off. All the accessories turn off (radio, fan blower, etc), but the engine stays running and fuel pump stays running of course. I have to put it in gear and dump the clutch to shut it down, and disconnect the battery to avoid the fuel pump and ignition draining it if I'm going to not be driving it for a while.
I've pulled apart the column and fiddled with the ignition switch adjustment, hasn't seemed to fix anything. I've swapped the ASD relay with a known good one, still no change.
What else am I missing?
