Catabeagle
I have everthing installed per instructions and it wont fire...any suggestions? ???:looser:
Got Propane kit? If so call em up..
Did it run on gasoline before? Like run well on gas?
1984 22r kit purchased from Nash fuelWhats it do? Just cranks never anything else
Lock off work? Yes
Gas On? Gas is on and has pressure
If you hit the "primer" button on the vaporizer do you hear a "hiss" and see vapors comming up from the mixer/carb? I don't think there is a primer button
Timming right? I don't know about the timing
Got spark? Have spark, cheched all plugs
Picture? I can email/txt pics from my phone
Not enough information.
So eliminate the electric vacuum switch????
The only electric hook up is one wire from the a vacuum switch attached to a fitting between the fuel supply line and the vaporizer. I removed it completely. Should I also take the fitting off and run the line straight in??
What kind of engine is your kit on? Did it fire the first try?
I have verified pressure through a "pressure test" screw/plug on the vaporizerThe electrical wire is running to the lock off...
Vacuum lock off systems have no electrical ****...
Is the wire tapped into a key on source??? Its onto the hot side of the coil
What kind of a tank are you using??? Fork lift??? 10 gal forklift
Can you hear the lines pressurize when you crack the valve open???
im sure its simle as well...Mine starts no matter what...
We need some pics...I can't upload pics on here from my phone...but I could email them from my phone
Is your kit all Impco parts??? Yes all Impco
Model E and a 300a??? I will check in the am
It's probably gonna be something really simple, but we're gonna need some more details...
Running your lock off on the same circuit as your coil is probably causing a weak spark. Try running a separate/dedicated feed for your lock off solenoid. Ultimately you should run a relay for the lock off that is keyed on but for now a jumper wire will do.
Check for vacuum leaks.
