MAD4WD Dana 60 Outer Axle Seal
Work with all Ford, GM and Dodge OEM housings manufactured from 3.125" with a .500" wall thickness.
Works with Original and Aftermarket 30 and 35-Spline Shafts.
Designed to prolong life of inner axle seals and keep dirt and water from entering housing.
Completely molded design with Nickel plated bodies.
Installed seal with silicon on outside, pack cavity with grease, install shaft.....done.
http://www.mad4wd.com/tek9.asp?pg=products&specific=jmrqgpese
