the_white_shadow
- Joined
- Dec 25, 2014
- Messages
- 816
Your midship looks very similar to mine and I'm also using the WOD carrier bearing setup. There's a thread on here that they recommend putting a piece of 1/4" umhv between the shaft and the mount to help with drivetrain movement. This is only if you're not running a slip in the midship. Or if you're not solid mounting your drivetrain. Just a FYI. Looking good.
