Glen1978
Sun does shine on a DOGS ASS!
Bought a JMR Raceline bender other day and decided I wanted it vertical so built a frame and got the HF 8 ton air ram to power it. Mounted the bender wheres its main arms are perfectly 90 degrees up and down like all the rest of em I saw. Put the ProTools 1.75" 240 die in and some HREW I had laying around and it sure is hell to get the the strap pin in and the follower pin in. First one is easy then the second is a PITA.
Another issue Im having is I thought one of the reasons to mount vertical is so that when you bend you just put the tube in and stick a angle finder on your "output" end and when you get the angle you want let off. Ok well my tube does not start off parallel to the ground.....it angles down coming into the bender. Can anyone help me out on this?
