Bronco 2.5 Full tuber
stompinjab1
This is a 72 Bronco
Chass is full tube 3 seater
Motor SB 350 TPI or TBI we have both
Trans TH 350
T case Klune to a 205
Front diff 2 1/2 ton steer, spooled, pinion brake,full hydro 4 link, 16" Sway away coil overs
Rear diff 2 1/2 ton steer, spooled, pinion brake,full hydro, 4 link, 16" Sway away coil overs
Tires 44" TSLs or 47" LTBs
This is the doner at the start
And how it looks now
Specs
107"to 109"
belly pan 24" from the ground
WMS 69 1/2
77" to 79" to top of cage
Ok finally got some more tube on it. Guess I better hurry if it's goin to be drivin May 1st
Ok due to some shop issues we just got back to work. In that time the TPI motor we had was a crusty 5.0.So now we just got the brand new balanced, blue printed,aluminum headed, full roller LT1 with plug and play harness. New TH350 , still the Klune 4.0 to NP205. And all specs are out the door due to the 54" boggers that we should see in 3 to 4 weeks Thanks to Super Swamper for the hook up:awesomework:
Ok friday we got some more tube on and the stock floor removed And today we got the motor, trans and cases set in and mounts started here are some pics
