wagonslayer
Is this the correct way for the spindle and caliper bracket to be mounted?
I will say that I rotate my key way around ,to the top, so I can see it better.
can you explain how you can do that? i think it can only go on 1 way..
This makes my brain hurt:redneck:
My spindles have a ground in notch for the half ton calipers to clear....I would have sworn I've reassembled with the notch out of position and had to take it back apart...weird.:eeek:
I believe the spindle studs are equal lengths between them so the spindle can be rotated to any spot (I believe mine is that way). And as jeff said keyway on top for ease of installing the lock for the bearing nut.
