Make sure you keep an eye on #4 injector line. I knew it was a common problem always check when I change the oil. Well 1200 miles after my last oil change the mount (the plastic part) broke loose and caused the injector line to break spraying fuel from the front to the tailgate. When I opened the hood I slammed it back down thinking it was on fire. I can only thank God my truck and family didn't burn to the ground. Crazy thing is we were on the last strech of a 12hr drive back home and one of my boys had to pee bad so I pulled over on the interstate and seen the smoke and smelt fuel. Geno's garage has an upgraded line for less than what a stock replacement from dorman costs. Btw I've owned the truck 9years so I've been checking it for years. When I checked the bolt it was tight but the plastic part had worn enough to allow the line to vibrate. thinking this is only third gen but not sure
Sent from my XT1635-01 using Tapatalk
