longfield
My electric fan switch controller keeps going out.I don't think i'm getting it wet maybe a little when i wash it. It's a Black Magic switch, is there a better one or what.
Thanks
Thanks
I had the same issues and then switched over to a painless type setup that uses a probe in the manifold and no more problems. It also keeps the temp more even since its reading the actual engine temp and not the radiators.
Does your system use a relay? If not then installing a relay and wiring it properly would most likely solve your problems.
Is this one of those jobies with the dial on it bobby?
I went through a few of those on my old RX-7 as well. The only time it possibly got wet was when I washed it. I dunno if theyre just shitty, or if that little amount of water really messes with them.Yes it has the dial on it.
So in the block instead of the Radiator. My promble is the ajusting switch not the prob. Is the switch in the other set up different?
Thanks Guys
