Oil can Well-Known Member Joined May 19, 2010 Messages 643 Location Lynden Jun 6, 2013 #1 The Toyota fifth stud is an effective easy mod to do. How did you do yours? Straight threw hole with nut on inside? Welded nut or not? No nut and tap the knuckle. What way worked for you?:eeek::corn:
Y Yotakid Well-Known Member Joined Mar 31, 2006 Messages 102 Location Cle Elum Jun 6, 2013 #2 Straight through with the nut welded on the inside. Now get that thing fixed and over here so we can go wheel!
Oil can Well-Known Member Joined May 19, 2010 Messages 643 Location Lynden Jun 6, 2013 #3 Yotakid said: Straight through with the nut welded on the inside. Now get that thing fixed and over here so we can go wheel! Click to expand... :haha: I'm on it...:redneck:
W wayne_fj40 Well-Known Member Joined Mar 27, 2006 Messages 1,153 Jun 6, 2013 #4 My weld didnt seem that great, so I also just put lock nuts on as well.
G GRW Well-Known Member Joined Apr 17, 2006 Messages 500 Location Everett WA. Jun 6, 2013 #5 Welded nut on the inside.
Oil can Well-Known Member Joined May 19, 2010 Messages 643 Location Lynden Jun 6, 2013 #6 What size nut and bolt?
JesterFab Well-Known Member Joined Apr 18, 2007 Messages 196 Location Everett Jun 6, 2013 #7 I think they all use 1/2" bolts. I did bend some 3/8" thick brackets for the fifth stud setup, but havent had an axle to verify fitment.
CHOP SHOP Well-Known Member Joined Sep 13, 2007 Messages 11,498 Location pierce county Jun 6, 2013 #8 Ive done it with a welded nut and with the nut on the outside too. Remember to center the knuckle and set the trunnion preload before doing the fifth stud. Then any futer adjustments will come out of the bottom cap.
crash2 -Oh no I picked a side- Joined Mar 26, 2001 Messages 39,839 Location Da gold bar Jun 6, 2013 #9 I have pretty detailed pics in this buildup. http://www.nw-wheelers.com/forum/showthread.php?t=5253 As Brad said make sure you set the trunion preload before you do anything.
JAWS Well-Known Member Joined Mar 25, 2008 Messages 2,000 Location orting Jun 6, 2013 #10 Ive seen people build their own with 1/4 plate and 3/8s bolt
