KarlVP
Love that TOYOTA
Do they just dump more fuel in the engine? I mean, you can't play with ignition timing cause it isn't there?
How do diesel tuners work?
Yes most of them change injector timing also.
the turner controls "recurves" the fuel delivery enrichment and timing. so it can lean the fuel and retard the delivery to gain mpg at cruise, and enrich and advance to gain power.
This explains a lot.
I was under the impression that the injector could only work during the intake stroke.
That being said, how can the tuner companies "guarantee" a MPG gain with them?
it does. but at what point in degrees of the crank shaft rotation on the intake stroke is where the injection timing and how much fuel is injected.
it would be easyer to sit down and draw it out in a graph or a picture to explain it.
In a nutshell they can say it but they can't really deliver. It's just playing the odds. How many people are going to try and follow through with the guarantee?
I found this graph, but the formulas make no sense to me.
So if all the tuner does is dump more fuel in the engine to make more power, how is it that I am saving MPG at a higher level?
This guy is. I've been playing with my tuner.
Bottom line is last tank of fuel I was driving like an old man on level 1 and averaged 17.5 MPG hand calculated. Almost EXACTLY the same daily drive as the last tank.
The previous tank I had the tuner set at level 2 for the entire tank. I averaged 20.2MPG hand calculated.
Weather was "about the same." Drives throughout the tank were almost EXACT.
EDIT: Driving style was the same too. I try as best as I can to keep the boost gauge from moving. The hills where I know it is going to move, I set the cruise control at the same speed. Same load in the vehicle.
Now keep in mind you economy could very well change one way or the other. I just don't think the tuner company can justify the "guarantee"...You driving style will dictate far more than the tuner will.
it brings on more fuel at lower rpm .
Are you sure the fuel map would be per RPM? I don't understand how that could work.......I don't think I've never seen a diesel tuning file. Does anyone have one they could post? Maybe a Tuner pro file?
