Rockwells607
I'm running a pretty healthy 358 with a 4000 stall converter, motor never really bogs, in only use 1st gear crawling more technical stuff and start in 2nd on hills
NTIDWELL said:yes I was running 205 with 400 with stock 6.0 blow the tires off until on steep hill then it'd bog motor down so I figured with the 2.1 205 I'd drop a cam in 6.0 and that would take care of that ended up finding a hell of a deal on stack 2.3 so dropped it in also world of difference still not gettn the speed I want So might need to change up motor or blow the motor I gots or it might just be me being a non driving **** beats me
xjpaddler said:what is randall key running??? pretty sure its ls1,t350, 205, and stock rocks. it always seams to have the woopow when needed.
3speed monster box 1.1 2.43 4.33Jhouser said:What stak did you buy that has a 2.3 range? I didn't see one listed on there site. That might be throwing your numbers off.
Elliott said:You sure your figuring that right? Transmission low gear x case low gear x axle gear. 15 should be a high geared pig
yes sir 1st gear puts me at 34.47 bounceing of rev don't run it much 2nd 24.16 pulls good bogs sometimes 3rd 16.32 every now and then can pull on hills. Showgirl 1st 37.67 he never runs it 2nd 22.48 this is gear he mostly runs 3rd 15.19 runs every now and thenTBItoy said:He's calculating with the trans in 3rd.
NTIDWELL said:???yes sir 1st gear puts me at 34.47 bounceing of rev don't run it much 2nd 24.16 pulls good bogs sometimes 3rd 16.32 every now and then can pull on hills. Showgirl 1st 37.67 he never runs it 2nd 22.48 this is gear he mostly runs 3rd 15.19 runs every now and then
yes sir very well could be a factorTBItoy said:Aren't you running big wide 44s on steel wheels?
Rotating mass is probably hurting you compared to showgirl too. 43 sx aren't that big or wide.
Elliott said:43's are heavier tho aren't they?I was thinking I was told the sidewalls are really thick, haven't ran them yet so not sure on that.
142 according to pitbullTBItoy said:They are 121 lb according to interco. I bet the pitbulls are 130-140, and a lot wider. Probably quite a bit taller too. 43 sx are only 40-41"
dats righthalcat said:You fellows are getting awful precise . He'll just feed that sum ***** more fuel and put it in any gear you want to.
NTIDWELL said:dats right
