Maverick26
As iron sharpens iron...
This is my orbital... It is the middle one recommended for an 8" ram.
http://www.trail-gear.com/orbitals-and-columns
Also, if someone could draw or tell me where in my system the cooler should be for best cooling? I have it on my return line but I am having second thoughts. thats where I thought it went.
I should say he doesn't need an extra res
My system is set up just like the graphic boxboy posted.
You have a external pressure relief valve?
Sorry Sir, my bad... I do not have one of those. Didnt know I needed one. Could this be the problem?
No it's built into the stock pump. Just making sure you didn't add another one to the system.
Oh ok, thats what I thought after I thought about it a little bit. So you think I could have an air lock in my lines somewhere? I really dont see anything else that could be the problem. Now that I need a new pump again I may get one that needs a remote res and mount it up higher then all my lines so I can get the air out... otherwise there is really no other way for me to bleed the system right now unless I put a bleed valve in somewhere but that could be a mess.
Up to .3% loss for every fitting.
also, wouldn't hurt to increase the size of your return line.
yep, use to have your same problem.. fixed it
