chrisf5651 Well-Known Member Joined Feb 24, 2012 Messages 391 Location Vina alabama Mar 23, 2014 #1 I have a divorced NP201 transfer case(NP200 as some call it). Is there a divorced transfer case that is as strong and will bolt up without making any changes? I am running a turbo 400 transmission.
J Jtremor Well-Known Member Joined Sep 15, 2013 Messages 108 Location Blytheville, Ar Mar 23, 2014 #2 the np205 is an option.
chrisf5651 Well-Known Member Joined Feb 24, 2012 Messages 391 Location Vina alabama Mar 23, 2014 #3 So the NP205 divorced shafts and case diameters are the same to just bolt straight up?
J Jtremor Well-Known Member Joined Sep 15, 2013 Messages 108 Location Blytheville, Ar Mar 23, 2014 #4 I honestly don't know the measurements on the 201. I could get you the measurements on the a 205 ford if you wanted it. I got one laying around.
fabricator1 Well-Known Member Joined Sep 16, 2012 Messages 493 Mar 23, 2014 #5 the 205 is very similar in size, but the 205 has a centered rear output and the np200 has the offset front and rear output shafts
