My guess (and guesses aren't worth much)......The timing chain is in wrong.....If it was loose enough that it could have jumped time and he looked at it and it was 2 teeth off.....There would have to be much slack on one side of the chain while the other side is tight. When he looked at it probably the wrong side was tight.
Do a compression test, I bet it's way low on all cylinders....:corn:
rick,
i didn't get to see how loose it was, i just remember him showing me how the timing marks were not lined up......
ok so going back to the begining the very start of all of this;
so last week or week prior he went out to the driveway and started the truck he said the truck started real wierd and made a funny sound (his words) i can't remember if he told me he rev'd it and the sound went away or if he turned the truck off and restarted it and it started up normal ( i am going to guess he restarted it) he drove it and it sounded fine for a 2 days, then on day 3 he went out and the truck would not start....
we then checked the plugs, he cleaned them up and checked the gaps
we put the spark tester on there and the light flashed red every crank
he checked the TBI, we got fuel...
he sprayed starter fluid in, cranked didn't start.
he then changed the GEARS and CHAIN, in time.........nothing
he then got on comancheeclub.com and asked the guys there.. they too said CPS, changed that........... nothing
he then checked the distributor and checked for missing teeth... none found
now we are here.......
now there is another guy on comanchee club saying that he had the exact problem on a brand new crate engine and it was his distributor, so he is going to buy a new one and try that... also he told me today he was going to check the compression so we will see where that goes....
