pos97TJ
I have a late 60's (68 I think) ford dana 60 rear and a disc brake setup for a 72-79. Will the hub assembly from a 72-79 rear 60 fit My spindles on a late 60's?
does the rotor mount on the back of the hub or the front onn yours. It seems that if I were to weld a mount for the caliper behind the flange on the axle that the clapier would sit to far towards the center of the axle and wear down the outer pad maybe. Correct me if I am wrong though I would definetly do that it seems like an easy fix.
