auburnaviator
- Joined
- Aug 22, 2007
- Messages
- 93
What brand have people used and had good luck with?
I've got a Mico-lock (manual lever style) set up as an E-brake; Seems to work very well....even still holds after sitting several hours!!! The reason I did this was the same reason you mention....that and I hate all the cable/fulcrum setup in Yota axles....uke:
jegs brand. Mount a switch on the dash, run the lock in-line. Cleaner and easier than a lever style IMO
but relies on power to hold it on and not intended to be used for more than a 30seconds...
Vee Dub guys use these too...
Park Locks for 45 bucks, I think I'm gonna order one up, works the same as the Mico Lock:
http://www.chircoestore.com/catalog/product_info.php?cPath=64_353&products_id=2113
Thanks for the warning, I'll definitely heed the advice.DO NOT run those. All it takes is the slightest pressure difference and they release. Watched my rig roll down the trail once due to them--biggest POS I have ever seen..
